Ealy 56 soft top bracket plate support ? - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    did all 56 corvette use the softtop bracket plate support ?
    my car does not have them now, and on the inside there is extra fiberglass mat under the riveted bracket plates
    and by looking at the rivets it seems a factory install but not sure
    thanks Sander,
  • Gary C.
    Administrator
    • October 1, 1982
    • 17929
    Re: Ealy 56 soft top bracket plate support ?
    Sander,
    Only if your '56 has a convertible top
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      If it was a Hardtop Only car, another telltale may be it is missing T-Nuts for 1/4-20 bolts in the body for the Soft Top side brackets. However I'm not sure if all Soft Top equipped 1956's had those. The only AIM we have these days is the 1956/1957 "combined".
      Also, if Soft Top, I think it should have the horizontal reinforcement riveted to the panel also. I can't see in the photo if traces of rivet holes there, like on this early '56 I once owned. Someone removed it along with the nutplates.
      Rich
      • Sander B.
        • March 1, 2005
        • 499
        Richard thanks for the pictures, the car has the traces of power top ( all the brackets are there) the T Nuts are also there,
        but it does not have the horizontal reinforcement strip and no holes ever been there (i have the panel bare fiberglass)
        the Vin is 261
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11363
          Sander,
          Since you found evidence of a Power Top, it therefore clearly included a soft top. Interesting.
          It may be possible that very early cars like yours did not include the horizontal reinforcement. But I would certainly think that the large plate reinforcements would be required, especially if power top.
          However, the picture above of my old '56 project car(long gone) vin 371, shows evidence of both the horizontal reinforcement, and the ST frame mount nut plates, But........no traces of the large Plate reinforcements. Hmmmm?
          If I remember this right, the cars built up to April(iirc apx 1800 cars) had the mandatory Power Top option. I am unsure if a RPO 419 Hard Top only (in place of Soft Top) was available on those early cars.
          Rich
