1958 built day one - NCRS Discussion Boards
1958 built day one
+ More Options
Posts
  • Gordon J.
    • November 29, 2016
    • 3
    1958 built day one
    Considering buying a 58 with very low serial number. It has a late 57 block, am I ok on this?
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 1958 built day one
    Gordon, need many more details to help you, vin number, engine casting number, stamps, etc. Early 58s are a mix of what was available upon assembly, if VERY early. I helped restore 58 003, a super untouched car, lots of non typical production parts etc. ( was a pilot line car)
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Gordon J.
      • November 29, 2016
      • 3
      Dan serial number is car number 15 casting is 3731548 I need to look at the car again but was told a end of production year date
      • Michael W.
        • April 1, 1997
        • 4290
        The casting date and assembly date of the engine must pre-date the assembly date of the car. I think 1958 production started around Oct.10th-15th 1957 so the engine must predate this.
        • Gordon J.
          • November 29, 2016
          • 3
          I was told a lot of 57 parts were used on the early 58 s including tail lights engine component s and such but did they actually use a 57 engine block ? Again, the car I am looking at has a 3731548 not a 3737739
          • Dan H.
            • July 31, 1977
            • 1372
            Gordon, unless there is history on that car back to its assembly, you're relying on unfounded information. You'll need more than that to present a car for others to agree on its authenticity. These are too pricey to guess on what it 'might of had' when assembled.
            Dan
            • Loren L.
              • April 30, 1976
              • 4104
              Dan, I can't remember the particular #s, but '58 003 did have a "548" block.
              • Dan H.
                • July 31, 1977
                • 1372
                Loren, yes it did, but it was made in Aug 57, also had a 57 part number on the frame, sand cast arm rest end pieces, FI unit was either 001 or 002, all sand cast. Was a running promotional display car, but not a 'first day of assembly' car, which might have been more sorted out. I'll look for any old notes I took, but most were given to its owner.
                Dan
                • James G.
                  • May 31, 1976
                  • 1556
                  It has been speculated that 1957 end of production was September 6, 1957, vin numbers 6917 THRU 6339 were made that day. Source MIKE HUNT, great historian we lost in June 2007 due to a stupid motorcycle accident. I would guess the first Monday there after would have 1958 production cars. I remember 003. The trunk interior was exactly 1957.
                  • Dan H.
                    • July 31, 1977
                    • 1372
                    Jim, the trunk on 003 was a 58 version, had clutch head bolts holding down bumper brace access cover plates, very different from 57 trunks and bumper installation. The clutch head bolts were 1/4-20 bolts with flat washer and lock washer and nut on underside. Later, like my 58 vin 297, the plates were held by screws into the fiberglass, a real time saver no doubt. The multi piece bumper brackets were simplified later in 58 to fewer pieces, on into 59 etc.
                    Dan
