C2 AC evaporator box restoration - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    Anyone know who does restoration on C2 air conditioning evaporator boxes?
  • Larry M.
    • January 1, 1992
    • 2701
    Re: C2 AC evaporator box restoration
    Tim:
    What are your needs??
    1. If fiberglass box itself needs repair, Scott Sinclair might be able to help/fix.
    2. If just seals, etc. are needed, DR REBUILD has the best rebuild kits around.
    3. You might also call Classic Auto Air in Florida and see if they do a complete restore. I believe they may do this, but am unsure about the final quality of the product. They offer rebuilding services for most AC parts. They have a good reputation in the AC industry, but not sure if their quality is what it once was.
    Larry
    • Keith B.
      • September 15, 2014
      • 1604
      there is not much to do on the box, remove the paint, then repaint. unless its rusty or dented up. if that is the case a little body work is needed
      • Gary J.
        • April 1, 1980
        • 1246
        You could glass bead the box, paint, put new seals in from Dr. Rebuild. Be sure to pressure test the evaporator core before re installing or buy a new one. The judging guide says gloss black. Also check out your fan motor.
