tachometer wiring - NCRS Discussion Boards
tachometer wiring
  • Martin M.
    • November 1, 1979
    • 124
    tachometer wiring
    I am trying to temporarily hook up an aftermarket Tachometer. it has 4 wires - black, red, yellow, Green. Any thoughts - I think the Black & Red are power for the tach. If the plug is different than I expected I am done.!
    Marty
    Beautiful Pahrump, NV.
    No smog, no rain, no winter, no hurricanes, no tornadoes,
    no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
    vetteheads.com alumni, Boston MA alumni
    1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
    1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
    1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
    1957 Chrysler 300 C 392 Hemi Car
    All for sale - most not cheap!!!
  • Philip A.
    • February 26, 2008
    • 329
    Re: tachometer wiring
    One is battery negative [black?], one is battery positive [red?], one is coil positive [green?], one is dash lights [yellow?]. guessing on colors
    • Donald O.
      • May 31, 1990
      • 1591
      Did you contact the tach maker help line?
      DonO
      • Joe R.
        • May 31, 2006
        • 1822
        Hi Marty,
        What is the manufacturer and part number of the tach? Did you try a Google search for a hook-up diagram?
        Joe
        • Martin M.
          • November 1, 1979
          • 124
          Thanks for the thoughts. Unfortunately I have no info about either tach. I guess I will go to NAPA and buy another cheap one, with instructions.
          Marty
          • Steven B.
            • April 11, 2012
            • 233
            I think Philip has it right. A little research showed that the green is commonly the coil lead. The black is commonly ground. If you try your yellow lead with a 12 volt source, and the black lead to the negative terminal of your source, and the tachometer lights up, then that leaves the red as a power lead. Good luck.
            Steve
            • Martin M.
              • November 1, 1979
              • 124
              Thanx Steve
              Marty
