1960's P/S control valve
Re: 1960's P/S control valve
I took the valve apart. Nothing has been cleaned yet except the ball stud and that needs to be replaced. It is rough not smooth.
Joe, I assume the spring on the right is the Corvette Spring?Attached Files
- Top
Harry,
Could you measure the 2, 12 point bolts (thread size and length) and post here? Also, is that a split lock washer on these? Thanks for your help.
Jeff- Top
Harry------
Please measure the free length of both of the 2 coil springs.In Appreciation of John Hinckley- Top
- Top
Cheers.
- Top
- Top
Harry, FWIW I overhauled the valve on my 63 a few years ago and got the kit from corvette stainless steel brakes in Miami and had no leaks or problems. I can't remember the gasket Joe refers to so I must have reused the old part.- Top
- Top
