1964 Drum brake self adjusters - NCRS Discussion Boards
  • David R.
    • February 1, 1990
    • 71
    When I disassembled the brakes on my 1964 Convertible, I discovered that the self adjuster levers and were missing on all four corners. I bought new levers and hardware from Corvette Central. The kit included an small clip (black phosphate finish) that I do not recognize.
    The levers are an odd two piece arrangement. After searching, I could not find any good pictures on how the pieces fit together. Can anybody help me:
    • With better pictures of how the levers fit together
    • Tell me where the clip goes?
  • Bob J.
    • December 1, 1977
    • 716
    Re: 1964 Drum brake self adjusters
    Looks like a brake drum adjusting hole plug.
    Bob Jorjorian
    • Dan H.
      • July 31, 1977
      • 1369
      Clip is a plug for the adjusting knockout slot. 63 shop manual has some pictures of brakes after assembly etc. Follow the directions for preliminary adjustments in the manual, good luck!
      Dan
      1964 Red FI Coupe, DUNTOV '09
      • David R.
        • February 1, 1990
        • 71
        That's what I thought, but it is loose and sloppy in the adjusting hole............
          • 43246
          David-------
          Once-upon-a-time there were guys that thought that brake self adjusters were "new-fangled" things that caused more problems and did nothing useful. So, they removed the self-adjusters and, thus, converted the brakes to old-style manual adjust only. That's probably why you found yours as you did.
          • Patrick C.
            • January 16, 2013
            • 327
            I just took my front drums off my 1964 today I will get you a picture tonight.
            • Patrick C.
              • January 16, 2013
              • 327
              Does this work?
              • Patrick C.
                • January 16, 2013
                • 327
                This is the passenger side front wheel
                • David R.
                  • February 1, 1990
                  • 71
                  Patrick, Thank You!!! A picture is worth a thousand words!!
                  • Patrick C.
                    • January 16, 2013
                    • 327
                    I hope it helps and i hope mine are together correctly. I have never driven this car yet.
                    • David R.
                      • February 1, 1990
                      • 71
                      Yours look correct. Since I did not have adjusters to reference, I did not understand where the spring on the adjuster lever was installed. I have my front "corner" assemblies on the shelf ready for installation on the chassis. I went back and reworked the adjusters on both.
                      I still need to assemble the rear swing arms. I have the hub and bearings assembled. I need to bolt them to the control arms next, then assemble the brakes.
                      • Doug L.
                        • March 14, 2010
                        • 442
                        Its been 3 years since I assembled my '64 so I don't recall exactly how things went back together but a photo of my brake setup is slightly different from the photo from Patrick, i.e. the angle of the black spring at 10 o'clock and the spring on a bar disappearing behind the center hub at 2 o'clock, that I think holds the 2 shoes apart.
                        • Frank D.
                          • December 27, 2007
                          • 2703
                          That flat steel bar with the spring is only on the rear brakes as you've shown -- the prior pic was a front brake setup.
                          Your black spring also looks to be installed a little more optimally then the one in the first pic ... sometimes you just do what you have to do to get them on though.
                          • Patrick C.
                            • January 16, 2013
                            • 327
                            As an engineer I would not design a spring installation that looked like mine. My car is a fuelie that has been setting in a garage since 1987 and i am getting it back on the road. I have been writing a series of articles on this car on the NCRS Oklahoma newsletter.
