1971 Jack repair Question - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    I have a 1971 jack that is in very ggod shape except the bottom plate which has been rusted and pitted. Can I remove the bottom plate from another jack and replace it. If yes, how do ou remove and replace the 2 pins and what year jack would have the same bottom shape?
    • 6957
    Re: 1971 Jack repair Quesion
    Paul, why not mix up some JB weld and skim coat the bottom plate and block sand?? these Jacks were really never made to take apart. Since they really are used for judging reasons, I would attempt a repair.
    • Paul C.
      • November 12, 2007
      • 511
      Would bondo or Eastwood contour glazing putty work?
        • 6957
        JB might be a better choice, but is a little hard to work with when sanding, Bondo is a little more absorbent to moisture and dampness will cause it to bubble, the choice is yours either will work.
        • Bob W.
          • December 1, 1977
          • 803
          I Agree with Ed JB would be the best choice. Try to add some liquid resin to thin it so it would spread a litter easer.
          Bob
          PS sandblast the bottom so it's real clean.
