1967 L71 alternator diodes - NCRS Discussion Boards
  • Hector G.
    • November 1, 2004
    • 234
    Recently received a 1 point deduction for "diode stamping missing" on the alternator at a recent NCRS chapter meet. Preparing to remedy this issue, I removed the alternator (part number 1100696, dated 7B6, Engine block casting C217, Engine pad stamp T0328 JE, Vehicle Production date 4/27/67) this morning. The car had just under 15k when purchased. I have driven the car approximately 500 miles. In my humble, and yes, bias opinion, I am convinced beyond a reasonable doubt that the car's odometer is correct. Will spare you the basis of the opinion. I mention the car's mileage for the following reason.
    I believe the alternator is original to the car. When I removed the alternator, I noticed that one of the stampings was just barely visible. The markings were as follows:
    423
    7A12
    466
    Here is my dilemma. The last 3 digits, "466" are not what the 67 TIM (6th Edition)
    calls for. The TIM indicates, on page 148, that the last 3 digits on three negative and positive diodes should read "467".
    I should also note that I have seen several John Pirkle Sr. restored 1100696 alternators, two with a February 1967 date with the "466" digits, not the "467" digits.
    Does anyone have an opinion on whether the TIM is correct and why?
    Thanks for your input.
    Hector
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 1967 L71 alternator diodes
    423
    7A12
    466
    Hector
    466 is good
    • Hector G.
      • November 1, 2004
      • 234
      Thanks Gene. Does that mean the TIM is incorrect?
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Most electronic components are/were identified with part numbers and date codes.
        I never researched the diodes but I'm wondering if the Manufacturer Part#(likely Delco) for one diode is 423466 and the other is 423467, one +polarity the other -polarity and stamped the date code between prefix and suffix.
        I don't know if individual diodes could have been purchased in service, maybe just the entire rectifier assembly for the Service Departments.
        EDIT....A little research. Individual diodes were available shown in this P&A catalog.
        My reference photos say the stamped component part numbers were 423466(POS) and 380466(NEG). I think the JG may be in error with the 467 designation.
