How to keep the 16 roller bearings in place in a borg warner transmission - NCRS Discussion Boards
  • Chester C.
    • May 29, 2013
    • 154
    I know you pack them in heavy grease but that's not even working. Every time I drop the shaft in the housing the tip always hits the bearings and upsets them. Any tips.
  • Steven B.
    • April 11, 2012
    • 233
    Re: How to keep the 16 roller bearings in place in a borg warner transmission
    Are you referring to the countershaft bearings?
    • Chester C.
      • May 29, 2013
      • 154
      Yes, I may have the number of roller bearings wrong, just a guess. It's the roller bearings that fit inside the pilot bore and you use grease to hold them In place on the side of the bore when trans gears goes in.
      • Steven B.
        • April 11, 2012
        • 233
        Cut a piece of wooden dowel that is the same diameter as the countershaft, to the same length as the countergear. Install the bearings in the countergear with the dowel holding them in place. Put the countergear in the transmission, and push the dowel out with the countershaft. The dowel will hold the the bearings in place as the countershaft slides into the transmission case and pushes the dowel out. The tailshaft housing will have to be off so the dowel can come out the back end of the transmission. It was about 30+ years ago that I had the same issue with a Muncie. Hope this is what you were referring to and that you have success in getting your transmission back together. Those bearings can be a pain even with a heavy wheel bearing grease.
        Steve
          • 6950
          Chetser, I Use Vaseline, or wheel bearing grease.
          • Joe R.
            • July 31, 1976
            • 4551
            Edward,
            Yes, Vaseline is the choice of those who build transmissions for fun and profit. The Vaseline will melt with heat and be replaced with trans oil. Some people say the heavy grease will not be replaced as the transmission heats up.
            Built them for years with axle grease and no complaints BUT it could happen any day.
            JR
            • Harry S.
              • July 31, 2002
              • 5330
              I used to use STP to hold them in. I don't even know if they make that stuff anymore?
                • 43247
                Steve
                Steve-------
                This is essentially how GM recommended it be done and how I do it. For Muncie transmissions there was actually a Kent-Moore GM tool for use as the dummy shaft. It was J-22246. The tool for T-10's was J-24658.
                • Steven B.
                  • April 11, 2012
                  • 233
                  You might want to double check the number of bearings the transmission takes. You don't want be short.
                  Steve
                  • Gary R.
                    • April 1, 1989
                    • 1799
                    I use trans gel- DR Goo green works great, No dummy shafts needed. I made a trans holder to build them.
                    • Steven B.
                      • April 11, 2012
                      • 233
                      Would have been nice to have trans gel back when. I believe I used the petroleum jelly aka Vaseline. The trans gel must be really sticky!
                      Steve
                      • Gary R.
                        • April 1, 1989
                        • 1799
                        Steve
                        The Dr goo stuff looks like a thick wax more then a gel. 5speeeds.com has some video on their site showing it in use. I pack the countershaft rollers complete, slide through the counter shaft and they are neatly packed. The main to input cage rollers I just pack and they don't move. Once the oil in the trans gets hot it will dissolve the goo and there are no after affects that I have seen. I have been using it the past 10-12 years now sure when it actually came out?
