1970 L46 Distributor Cap and Rotor OEM number. - NCRS Discussion Boards
  • Stephen V.
    • July 23, 2016
    • 30
    I'm looking for the OEM numbers for a 1970 L46 Distributor Cap and Rotor. I'm assuming they were Delco Remy numbers. Also assuming the cap was stamped with Delco Remy PAT PENDING R. Thanks for any help or guidance.
    • 43273
    Re: 1970 L46 Distributor Cap and Rotor OEM number.
    Stephen------
    Cap-------GM #1971244, aka Delco D308R
    Rotor-----GM #1971247, aka Delco D409R
    I believe that originals were embossed as you mention. Keep in mind that these same part numbers were used over a VERY long time and nuances of configuration changed over the years. So, while you might find NOS parts under these part numbers, that does not guarantee that they're 100% NCRS-correct.
