1963 ground wire under hood - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Book says ground for carb. cars ground screwed to core support. On FI cars it does not say. Does the FI cars screw to the part of the air cleaner that mounts to the core support and if so what screw does it mount to? Thanks in advance.
  • John D.
    • December 1, 1979
    • 5507
    Re: 1963 ground wire under hood
    Jerry, This is in the 6th edition I believe. Always been a topic of discussion as to the outside star washer for the ground strap. Hooks to the accelerator "flat" lever coming off the firewall.
    I forget what my 63 FI car has. With or without a washer and have lost interest in having it judged anymore. John D
    • Jerry C.
      • November 1, 1995
      • 741
      JD I was asking about the ground from the wiring harness for proper mounting position on a FI car. Thanks
      • John D.
        • December 1, 1979
        • 5507
        Jerry, Are you referring to the ground wire that goes on one of the AC S-tube to radiator support?
        • Jerry C.
          • November 1, 1995
          • 741
          Yes, do you know which screw does it go on? Thanks
          • John D.
            • December 1, 1979
            • 5507
            I already told Jerry on the phones and with a pic gang. But FYI. The Ground wire goes on the top left Screw (with L logo. The screw closest to the inner fender.
            QT: I was under the impression the the 63 and early '64's all used a screw/bolt with an "L" logo. Yet I see guys on Ebay advertising other logos as correct.
            We know GM used various suppliers.
            But for the "S" Tube to radiator support on the FI cars is there in fact more than one logo??? Thanks, John
            • Bob J.
              • December 1, 1977
              • 720
              L is the correct headmark for 63 for that ground wire.
              I have never seen any other headmark but L in the past 40 years when looking at unrestored cars.
              Bob Jorjorian
              • Dan H.
                • July 31, 1977
                • 1372
                Agree with Bob on the 'L' screws. Mine still had them, 1964 Vin 13708. Same part number through 65, but think the line workers put in the high hat type when they could snag some, late 64 and 65?
                Dan
                1964 Red FI Coupe, DUNTOV '09
                • Alan D.
                  • January 1, 2005
                  • 2054
                  Also agree on the "L" screws & location of ground, original on 1964 VIN 13901
                  • Michael G.
                    • November 12, 2008
                    • 2158
                    Here's a pic showing the original screw on a fuelie. Note the 'L' head marking.
                    Mike
                    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
