'67 Rally Wheel - NCRS Discussion Boards
'67 Rally Wheel
  • Leif A.
    • August 31, 1997
    • 3630
    '67 Rally Wheel
    Does this decode as a '67 Corvette Rally Wheel? And, if so, what do the letters and numbers mean?
    Leif
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: '67 Rally Wheel
    Leif,
    My 67 is also DC and that was what I was told the rims for 67 had. I also think (in the forum) that there was another letter code for a different build time. My 67 is a may baby.
    Dom
    • Edward B.
      • March 29, 2013
      • 691
      Re: '67 Rally Wheel
      K18 4 25 DC
      K - Manufacturer (Kelsey-Hayes)
      1 - Assembly plant (Romulus, MI)
      8 - Year of manufacture (1968)
      4 - Month of manfacture (April)
      25 - Day of manufacture (the 25th)
      DC - Wheel code/application (15x6 Rally used on 1968 full size passenger cars)
      • Domenic T.
        • January 29, 2010
        • 2452
        Re: '67 Rally Wheel
        Leif,
        Took a look in some old posts and they are saying DC is a 67. Although what Edward has makes one think!
        Dom
        • Edward B.
          • March 29, 2013
          • 691
          Re: '67 Rally Wheel
          The Rally wheel "DC" code was used in 1967 on the Corvette (and on station wagons with disc brakes). In 1968 (the date on the wheel in question) it was used only on full size cars. It was also used in 1969 on full size cars.
          You could still use it, but the date would be wrong. And since the date is hidden by the trim ring, who would care!
          Ed
            • May 31, 1974
            • 8385
            Re: '67 Rally Wheel
            no trim ring on spare so date important at that location. mike
            • Timothy B.
              • April 30, 1983
              • 5186
              Re: '67 Rally Wheel
              Plus, on original production line wheels a 25 cent piece (quarter) will pass through the holes around the circumference. Later K/H service wheels for some reason have smaller width holes. I am not sure about the smaller DC stamped wheel like this one.
              • Edward B.
                • March 29, 2013
                • 691
                Re: '67 Rally Wheel
                Mike, I don't have my car judged, but do they make you drop the spare during judging??
                Ed
                  • May 31, 1974
                  • 8385
                  Re: '67 Rally Wheel
                  they sure do. the tire, rim and tub as well as spare tire tub lock get judged. mike
                  • Edward B.
                    • March 29, 2013
                    • 691
                    Re: '67 Rally Wheel
                    Thank you sir!
                    Ed
                    • Michael M.
                      • February 7, 2011
                      • 186
                      Re: '67 Rally Wheel
                      Leif
                      This is one of the best articles I've run across regarding '67 Rally Wheels.
                      • Leif A.
                        • August 31, 1997
                        • 3630
                        Re: '67 Rally Wheel
                        Originally posted by Edward Bertrand (58273)
                        K18 4 25 DC
                        Ed,
                        This makes perfect sense. These stamps are only on the R/R of my '67. I would hazard a guess that one wheel was damaged and replaced with one from service made in 1968. Thank you for decoding for me. The wheel slots allow a quarter to pass thru on all of the wheels with 1/8" to spare. Part of this stamping is visible thru the valve stem hole. Again, thank you.
                        Leif
                        • Leif A.
                          • August 31, 1997
                          • 3630
                          Re: '67 Rally Wheel
                          Originally posted by Michael Mayland (52812)
                          Leif
                          Michael,
                          Thank you for the PDF. Great article and concurs with what Edward stated earlier.
                          Leif
                          • Jeff S.
                            • July 31, 1984
                            • 384
                            Re: '67 Rally Wheel
                            Only the YS code 15x6 rally wheel ('69 & later, service rplmt, el canino, etc.) slots will not allow a quarter to pass through the slot radially. Small DC, FI, DF, large DC, DG, B, and the like all have full width radial dimension slots & will easily permit the quarter to pass. Photo below illustrates YS stamped as follows: K1 0 6 (valve stem) 18 YS (Jun 18, 1970), Hoop 15x6 JK
                            • Timothy B.
                              • April 30, 1983
                              • 5186
                              Re: '67 Rally Wheel
                              Hi Jeff,
                              I had two FI stamped wheels and I bet my friday night pizza that the quarter will not pass through. :-) I am pretty sure about this unless my memory is completely going.
