1965 Hardtop Window Date Code Question - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2926
    My car is a Feb 26 build convertible. It has what I believe is the original hardtop with a window dated coded A F. The Judging Guide indicates that A is for Jenuary which seems right but the year should be E. I've looked closely at my "F" to see if it might be an "E" but it doesn't appear to be. Are there any 65 garu's out there that may have some insight into this.?
  • Jim D.
    • 2884
    Re: 1965 Hardtop Window Date Code Question
    The hardtop rear window on my early May 65 is E/B (Feb. 65).
    • Dave S.
      • August 31, 1992
      • 2926
      Thanks Jim. Yours is right in line with the judging guide.
      in my case to further complicate things my "A" (for January) is in the lower left and the "F" is in the upper right. Likely a human error but........
      • Jim D.
        • 2884
        They changed the format for 66-67. A "F" in the upper right indicates a 1966 and a "G" indicates 1967. The month stamp for those two years would be in the lower left, the opposite of the 1965 format. Your stamp indicates a Jan. 1966 date.
        • Dave S.
          • August 31, 1992
          • 2926
          JIm,
          Thanks. That explains things. This car was equipped with a hardtop when new (as per window sticker) but I guess somehow along the way this 1966 top was acquired. It's a beautiful original top but I don't want to invest in repainting it if it has the wrong dated window.
          • Jim D.
            • 2884
            JIm,
            Possibly the rear window was replaced and that is the original top for your car.
            • Dave S.
              • August 31, 1992
              • 2926
              Jim,
              Obviously it is a judging problem so it's best to just replace the window. It needs a repaint and a headliner so I think that's what I will do.
              Thanks for the guidance.
                • 6948
                Dave, do think you would like a 10/64 dated rear hardtop glass? I have one and I would consider pretty good shape, So the dating may work??
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Here's the one on`my late '65 (not the original top). I interpret the upper right as May, and the lower left corner as calendar 1965.
                  • Dave S.
                    • August 31, 1992
                    • 2926
                    Ed,
                    you have mail
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      Dave,
                      Here is my thought on the E & F characters. Are not the digits set one at a time? That's my impression. Being that the case if an "E" is not set flat with the window I could see the bottom leg of the "E" be unimpressed leaving you with a"F".
                      Did you put an eye loop to it? Maybe you will see more.
                      In my experiences the digit size, tilt, attitude, and depth of impression is all over the map on original known tops. And yes this makes it easier to "fabricate dates" that look typical.
                      • Dave S.
                        • August 31, 1992
                        • 2926
                        Originally posted by Gene Manno (8571)
                        Dave,
                        Gene,
                        i did look at it magnified. If it was a mis-hit it was a perfect one. As I mentioned of further issue is that the location of the month and year Stampings are reversed. Apparently 66 up did it different than 65.
                        • Jim D.
                          • 2884
                          That is correct.
