Delco Remy - NCRS Discussion Boards
Delco Remy
  • Don B.
    • September 1, 2014
    • 46
    Delco Remy
    Does anyone know the part number for the Delco Remy ballast resistor for a 62 Fuelie? Also, looking for a transmission ratio tag for my 62. Should have JJ embossed on it
    Don
    • 43213
    Re: Delco Remy
    Don
    Don-------
    GM #1931385.
    • Don B.
      • September 1, 2014
      • 46
      Re: Delco Remy
      Thanks Joe
      • David L.
        • July 31, 1980
        • 3310
        Re: Delco Remy
        Don,
        My 1962 Delco-Remy Popular Parts Catalog (June 1962) lists # 1931385 for 1956-1962 Corvettes but does NOT give a Delco-Remy part number. It also lists GM # 1115091 & Delco-Remy # D-501 for the Ignition coil.
        My 1966 Chevrolet Parts Catalog describes the 1931385 as RESISTOR, primary (black dot)((0.3 ohms).
        GM # 1957154 is described as RESISTOR, primary (blue stripe)(1.8 ohms).
        Dave
          • 43213
          Re: Delco Remy
          Originally posted by David Liukkonen (3775)
          Don,
          Dave
          Dave-----
          The Delco part number for the GM #1931385 resistor was D-1111. That number won't be found in a GM parts catalog, however.
          By the way, GM #12336832, aka Delco C-1101, replaced the above-referenced for SERVICE. It's discontinued now, too, though. It was configured somewhat differently than the 1931385 but, presumably, it would be a functional replacement.
          • David L.
            • July 31, 1980
            • 3310
            Re: Delco Remy
            Dave-----
            Joe,
            It's odd that the Delco-Remy part # is not listed in my 1962 Delco-Remy Parts Catalog for the 1931385 resistor but the Delco-Remy part # for the 1957154 resistor is listed as D-1110. At least there is some logic to the Delco-Remy part number system.
            Dave
            • Don B.
              • September 1, 2014
              • 46
              Re: Delco Remy
              Thank you gentlemen. Now all I have to do is find one
                • 43213
                Re: Delco Remy
                Don------
                Keep in mind that this ballast resistor was manufactured for a LOT of years. So, there are likely to be minor differences depending on when each one was manufactured. For an example that's 100% correct you'd probably have to find one that was manufactured about the same time as your car was built. I would not go that far, though; if it were me, any 1931385 would be fine.
                You should not have too much trouble finding a 1931385. They're out there. You'll likely have to pay about $100-200, though.
                • Don B.
                  • September 1, 2014
                  • 46
                  Re: Delco Remy
                  Joe,
                  I have not found one yet but will keep looking.
                  Thanks for your advice,
                  Don
                    • 43213
                    Re: Delco Remy
                    Joe,
                    Don
                    Don-------
                    Here's one:
                    • Pat H.
                      • December 1, 1996
                      • 419
                      Re: Delco Remy
                      That may be the functional replacement, but it's missing the tang at the top as per the TINJG
                      • Don B.
                        • September 1, 2014
                        • 46
                        Re: Delco Remy
                        I too noticed the missing tang on the top of the attaching bracket. Will keep looking until I find as per the TINJG.
                        Thanks for your help.
                        Don
                          • 43213
                          Re: Delco Remy
                          Don
                          Don------
                          Yes, the "tab" is one of the nuances that disappeared over time. As far as I know, this "tab" has no functionality and is simply an "artifact" of the stamping process for the bracket. In any event, to find an NOS example of a resistor that features this nuance will be difficult and, no doubt, expensive. You may be able to find a used example. I don't like used electrical parts, though. I'd much rather have an NOS piece without the "tab" than a used piece with the "tab".
                          • Don B.
                            • September 1, 2014
                            • 46
                            Re: Delco Remy
                            I found a couple of correct looking ballast resistors. I am in the process of finding out the ohm ratings of resistors to see if they will work on my car.
                            Don
                            • Pat H.
                              • December 1, 1996
                              • 419
                              Re: Delco Remy
                              I'd be interested in the ohm value as well. I have a service replacement that is mark 2.0 ohms. I remember reading somewhere where it was much less, but can't seem to find it. A number of .3 ohms rings a bell, but I've also seen 1.8 ohms somewhere as well.
