Help!
Had to have my 84 Corvette towed home the other day because I could not open my hood to reconnect my battery. The emergency aftermarket cables I had installed earlier were of no use either. No matter how hard I pulled on the release cable nothing happened. I ordered the special tool to pop the hood if the cable breaks but it is like threading a needle in the dark. I am still trying to make this tool work. Instructions are not real clear and instructions even suggest cutting 1/4 inch off the tip of the tool if necessary, but I don't know if it is necessary.
What is the last resort to open this hood without cutting it apart? I am ready to start taking the car apart if necessary. I am really frustrated and need some good advice right away.
Thanks to anyone with a solution.
Had to have my 84 Corvette towed home the other day because I could not open my hood to reconnect my battery. The emergency aftermarket cables I had installed earlier were of no use either. No matter how hard I pulled on the release cable nothing happened. I ordered the special tool to pop the hood if the cable breaks but it is like threading a needle in the dark. I am still trying to make this tool work. Instructions are not real clear and instructions even suggest cutting 1/4 inch off the tip of the tool if necessary, but I don't know if it is necessary.What is the last resort to open this hood without cutting it apart? I am ready to start taking the car apart if necessary. I am really frustrated and need some good advice right away.
