1963 radiator core - NCRS Discussion Boards
1963 radiator core
  • Frank D.
    • December 26, 2007
    • 2703
    Re: 1963 radiator core
    Frank, my PG '63, #3393, does NOT have the opening and, obviously, does NOT have the trans oil cooler.
    Most interesting, Alan. Provision for PG oil cooler on a car for which PG was NOT an option
    Indeed ...
    • Kim C.
      FYI, part in the LIC photo is the Coffman repro.
      if you have questions contact Coffman direct.
      • Jim L.
        • September 30, 1979
        • 1806
        Hmmmm.... this thread is becoming too settled.... Frank, are you aware that there are differences in the radiator shrouds depending on whether they are intended for use on core supports with/without the trans cooler hole?
        • Frank D.
          • December 26, 2007
          • 2703
          Well damn....not just no, but heck no! Fill me in.. Is the difference in the AIM ?
          My original shroud SHOULD be OK though as the car's radiator core support had the transmission cooler hole.
          At least I scored an original radiator core support today off a good friend from a convertible with a serial number below 700!
          Took some "horse trading" though!! Stabilized the very mild surface rust after this pics and will paint it in the morning...
          • Jim L.
            • 1806
            Frank,
            Look closely at Rich's picture in posting #12. In the vicinity of the now-famous hole, you can see the shroud has a slight notch to clear the punch-out area around the hole. On core supports without the hole, like on my '63 for example, there is no notch in the shroud.
            Jim
            • Bob W.
              • November 30, 1977
              • 799
              Jim I see the notch in post #12. My PG car dose not have the notch. I have owned this car since 1971. And I didn't change the shroud.?????
              Bob
              • Bob J.
                • November 30, 1977
                • 713
                Originally posted by Frank Dreano (48332)
                Bob, as I said, that 63 convertible has been around a LONG time and was found last month just a few miles from where the dealer (long defunct) first sold the car here in Winter Garden
                Frank, that would have to be Thriftway Chevy, downtown Winter Garden.......long gone now.
                I found some interesting parts in their inventory after they closed.
                Bob Jorjorian
                • Frank D.
                  • December 26, 2007
                  • 2703
                  Yup.... I saw the title on the car and that's who sold it....VERY cool picture...
                  I'll share it with the new owner (whom you almost certainly know)...
                  That's the car providing the radiator support pictured above...a two owner car (transferred from the buyer to his brother, both now deceased) and has never been out of Winter Garden...
                  JIM: Confirmed I have the notched shroud -- thanks for that extra bit of knowledge...
                  • Jim L.
                    • 1806
                    #24
                    Bob
                    Very interesting, Bob.
                    I can think of two possibilities to explain the configuration on your car:
                    1. The addition of the notch in the shroud did not happen concurrently with the addition of the hole in the core support. If true, there would/could be other '63s with "late" support and "early" shroud".
                    2. At some time before you owned the car, it sustained front end damage and needed a new shroud. Somehow, an early shroud was located and used as a repair part.
                    Do you know any history of your car prior to the time when you acquired it? And can you post a picture of the area around the hole? I'm curious to see how well the non-notched shroud fits and works.
                    Jim
                    • Frank D.
                      • December 26, 2007
                      • 2703
                      #25
                      Confirmed this morning my May car has the notched shroud....so the original core support I picked up will now match nicely...
