1969 Front Support Finish - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 258
    Doing a frame off on a 1969 convertible and have a question on the steel angle support that is installed inside the 'nose' section in the front. The car has been been painted in the past so I can not determine, what was the original finish on the steel support and should it have some 'over spray' on it? Thanks for any information. Steve
    • 43273
    Re: 1969 Front Support Finish
    Steve------
    If you're talking about the slightly "V" shaped reinforcement which is riveted to the surround panel, it was dip painted semi-gloss black.
    • Steve M.
      • January 1, 2006
      • 258
      Thank for the feedback. Steve
        • 3418
        Hi Steve,
        Because the reinforcement was bonded in place when the body was painted and it's location, there was the possibility that particularly the surface that faced the engine compartment could have some body color overspray on it.
