1970-1972 battery ground cable bolt on frame - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    In the assembly manual on UPC 12, Sheet A11 there is a Note 7 bolt 180143. What bolt is that and what is the correct headmark?
    Scott Sims
    Texas Chapter
    • 43259
    Re: 1970-1972 battery ground cable bolt on frame
    Scott Sims
    Texas Chapter
    Scott------
    GM #180143 is a 7/16-14 X 3/4" standard hex bolt. It was a trimmed (non-indented) head bolt of GM-280M material grade (SAE grade 5; 3 lines). It was zinc plated. One headmarking was RBC but there were likely many different suppliers, especially for a very common-size bolt like this.
    • D S.
      • March 1, 2005
      • 1551
      Joe, thank you for your prompt reply.
      Scott
      • Rich P.
        • January 12, 2009
        • 1361
        I see alot of TR next would be RBW and RSC. BUT I could list 10 different headmarkings I have seen in this application.
        • D S.
          • March 1, 2005
          • 1551
          Thanks, Rich. That helps.
