Alternator 1962 new - NCRS Discussion Boards
Alternator 1962 new
  • Ed P.
    • August 10, 2014
    • 89
    Alternator 1962 new
    I want to install a new alternator. 1962 327ci. 4 speed. Need help into what kind of alternator should i use?
  • Mike M.
    • May 31, 1974
    • 8408
    Re: Alternator1962 new
    62 corvettes used generators, not alternators. however, any first generation GM alternator(with external regulator), will mount using gm bracketry. 2nd generation gm alternators, with internal regulators, will also mount using gm bracketry . mike
    • Ed P.
      • August 10, 2014
      • 89
      thank you mike
      i have a voltage regulator on the car and it is new
      • Ed P.
        • August 10, 2014
        • 89
        Mike all the alternaters i see on Summit Racing have internal regulators, then i would have to take out the regulator that is there now?
        ed
        • Mike M.
          • May 31, 1974
          • 8408
          yes, the old generator regal;ator would need disconnected from your wiring harness. the alternator from summit should have instructions on wiring the alternator to the old c-1 harness. mike
          • Gene M.
            • April 1, 1985
            • 4233
            Ed
            Understand this is not a "restoration" action putting an alternator as Mike said. But if you are dead set on an alternator there are plenty of step by step procedures and availability on the inter web. Here are a few to get you started some dealers some tech.
            DB Electric offers top aftermarket parts nationwide for auto, boat, and industrial needs. Discover quality and reliability now!
            http://bob_skelly.home.comcast.net/~...ternator1.html
            http://67-72chevytrucks.com/vboard/s...d.php?t=604881
            • Terry D.
              • May 31, 1987
              • 2697
              Ed
              Make sure you read the one from Mad Electric mentioned by Gene, especially the article about one wire alternators! Mark is a wealth of information, but as John Hickley once told me there are only two things wrong, one, he is hard to reach by phone and two he is hard to get off the phone, LOL. He was a tremendous help to me in rewiring my 62 for an alternator, stereo with two amps, changing the amp gauge to a volt meter.
              • Ed P.
                • August 10, 2014
                • 89
                Terry we spoke on the phone in Feb. regarding my windshield, and again thank you for all the info you sent me.
                tanks
                EDD
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Re: Alternator 1962 new
                  A "new" alternator ?
                  Meaning you are already running one...
                  If not, what is wrong with your generator ?
                  Unless you've added a bunch of accessories a generator works perfectly..
                  I ran the original in my '61 for a dozen years including driving a 650W stereo amp...
