upper a frame bumper stops - NCRS Discussion Boards
  • Phil A.
    • April 30, 1982
    • 121
    Who knows the easiest way to install upper a-frame bumpers with the coil spring installed but the upper a-frame out of the way?
    • 43285
    Re: upper a frame bumper stops
    Phil-----
    If by "out of the way" you mean with the upper a-arms removed, it's no problem to install the bumpers. Simply lubricate the "peg" on the bottom of the bumper with soap or silicone rubber lubricant and press it into the orifice in the frame.
    The coil springs have absolutely nothing to do with this. You can remove the upper a-arms without touching the coil springs.
    By the way, the bumpers, originally GM #3742247 and last available under GM #384220, are discontinued. However, I'm sure they're available in reproduction.
    • Bill L.
      • February 1, 2004
      • 1403
      I just did this on my 70. I used common liquid soap to lubricate the bumper and I found that by pressing and twisting at the same time it went in without issue.
      Kind Regards,
      Bill
        • 3419
