'65 FI oil pan ??? - NCRS Discussion Boards
'65 FI oil pan ???
  • George W.
    • May 31, 2000
    • 544
    '65 FI oil pan ???
    Which (if any) of the trays in photo is correct for the '65/375hp oil pan shown?
    And, how many of and where do I purchase the main cap bolts/studs to mount this?
    • 43285
    Re: '65 FI oil pan ???
    George------
    There's no photo attached. However, the baffle for your application is as pictured in the following eBay item (the one pictured is a reproduction but its configuration is pretty much the same as original and it's a lot easier for me to reference this one than go out and dig out an NOS example I have).
    As far as the studs go, your original studs were likely GM #3815532. These were discontinued in mid-1965 and replaced by GM #3872718. Unfortunately, the latter are also now discontinued. However, I would expect that reproductions are available. You need 5 of these studs.
    • George W.
      • May 31, 2000
      • 544
      Thank u Joe,
      i do have the correct tray(wonder what happened to the photo? Maybe to large?)
      trying to find the bolts
      g
