Sending unit o ring or gasket. - NCRS Discussion Boards
  • Michael K.
    • January 14, 2013
    • 99
    Installing sending unit on new tank in 64. I see the o ring fits nicely between the tank and unit. The sending unit also came with a cork gasket. The AIM doesn't show where the gasket goes. It appears there would be a good seal with the o ring. Is the gasket supposed to go between the o ring and unit? Doesn't seem likely but want to be certain. I don't want to mess with a gas leak. Thanks! Michael Kalogridis 518 248-1105
  • Don H.
    • December 1, 1981
    • 1491
    Re: Sending unit o ring or gasket.
    Michael, If I remember right (dangerous), I only used the o-ring. I don't recall using a gasket. Good luck, Don H.
    • Joe R.
      • July 31, 1976
      • 4551
      Michael,
      The cork gasket goes on the fill neck. Only the rubber O rings goes between the tank and the sending unit.
      Those two gaskets are packed with the tank and sending unit.
      JR
      • Frank D.
        • December 27, 2007
        • 2703
        Prob worth changing the filler neck gasket too though....especially if you're getting a gas smell...
        On my 63 the filler neck mounting screws have integrated rubber O rings that go bad too...you'll want those if a '64 uses 'em...
          • 43246
          Frank and Michael------
          I like cork for lots of things but not for the filler neck gasket even though that's what was originally used. I make up a similarly configured gasket from a sheet of about 3/32" thick buna-N material.
          The screws with integral rubber seal, GM #3767804, were used for all 1963-74 Corvette filler necks. They are essential and the seal must be in good condition.
          • Dan B.
            • July 13, 2011
            • 545
            Ethanol%20&%20E85%20Material%20Compatibility.pdf
            In checking out Buna-N, I found this disturbing document regarding Ethanol compatibility. According to this, many of the components in our fuel systems are not compatible like brass, tern plating, and cork. Sorry I looked, but it explains a lot of things I have been seeing. The title "Ethanol Fill up Feel Good" gave me a laugh. Dan
            See top of page for link. Was having trouble getting this to post.
              • 43246
              Originally posted by Dan Bachrach (53579)
              [ATTACH]73240[/ATTACH]
              In checking out Buna-N, I found this disturbing document regarding Ethanol compatibility. According to this, many of the components in our fuel systems are not compatible like brass, tern plating, and cork. Sorry I looked, but it explains a lot of things I have been seeing. Dan
              Dan------
              I made my filler neck gaskets prior to the advent of ethanol-blended fuels. However, I think the compatibility problems with ethanol are likely based upon straight ethanol or gasoline with a high percentage of ethanol (like E-85).
              In any event, the Buna-n is better than cork as far as ethanol compatibility goes. Actually, I'd prefer to make the filler neck gasket from a sheet of Viton if I could find it.
              GM has approved the use of gasolines with up to 10% ethanol for all of its vehicles going back quite a few years. However, I don't know just how far back this approval goes. Finding widely available gasolines not blended with up to 10% ethanol is becoming increasingly difficult in some areas of the country. In California, it's virtually impossible.
              • Dan B.
                • July 13, 2011
                • 545
                Joe, well thanks I feel a little better now
                Where is a good source to get Buna N?
                I'd like to try making some gaskets out of it.
                  • 43246
                  Dan------
                  I bought mine at an industrial supply company which specialized in elastomers but it was a long time ago and I don't recall the name of it. I think you can probably find it online. Buna-N is a VERY widely used material, especially for fuels and lubricants. Grainger might be one firm that could supply it.
                  By the way, I did a little online research since I last posted and I did find Viton sheet material. The problem is that a 36" X 36" size piece (the smallest available) of 3/32" thickness costs almost $500.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    The "O" Ring Store has small sheets of Buna N...!
                    • Michael K.
                      • January 14, 2013
                      • 99
                      Thank you all very much. Michael Kalogridis
                      • Gary B.
                        • February 1, 1997
                        • 7046
                        Joe,
                        Amazon has 12"x12"x3/32" sheet Viton for $70.69 + $6.99 shipping. Sourced from Grainger, I think.
                        Gary
                          • 43246
                          Originally posted by Gary Beaupre (28818)
                          Joe,
                          Gary
                          Gary-----
                          That sounds better. A 12" X 12" would be sufficient for me to make the filler neck gasket + several other fuel-resistant gaskets I might want to. This might be worth 70 bucks. While I might be crazy enough to spend this kind of money for a few gaskets that probably amounts to extreme "overkill", I really think that the Buna-N is completely sufficient for the filler neck gasket.
                            • 15706
                            The title on the sheet is "Ethanol & E85 Material Compatibility", which implies 100 percent ethanol & E85, so it doesn't necessarily apply to either straight gasoline or E10. However Buna-N is listed as compatible and we know it's compatible with straight gasoline, so a logical conclusion is that Buna-N is fully compatible with E10.
