'59 rear axle bearing---need crossover reference - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    My '59 rear axle bearing housing has a 3" diameter cavity that is 7/8" deep (no shim).
    The replacement bearings are 3.0" x 1.0" thick.
    I need the original maker(s) identification number and/or the exact dimensions/specifications for the 7/8" bearing so I can find a substitution. Need retaining ring also.
    The bearing removed is 7/8" with one o ring, ball bearing type, with the oil seal (6971-s) on the out board side.
    Thank you,
    George
    • 43279
    Re: '59 rear axle bearing---need crossover reference
    Thank you,
    George
    George-----
    Here's what GM says: originally, there were two bearings, one for cars with positraction and one for cars without posi:
    original for cars with posi---GM #7451112, aka Hyatt JRN1542-WAB-23. This bearing was discontinued and replaced by GM #7451415. The latter was discontinued and replaced by GM #907294, aka New Departure RW-607BRSY1Z. The 907294 is also now discontinued.
    original for cars without posi----GM #3746787, aka New Departure RW607SY12. This was discontinued and replaced by the same GM #907294 as shown above.
    The BCA replacement for the 907294 is RW607NR.
    • George W.
      • May 31, 2000
      • 544
      Humm?
      My center pig is a posi, but it seams I have a non posi carrier?
      So, the non posi bearing is the 7/8" deep by 3" diameter Bering?
      thanks again
      G
        • 43279
        Humm?
        thanks again
        G
        George-------
        Sorry, I don't have dimensional specs on these bearings. Perhaps someone else will have the answer.
