1970 LT1 Corvette Engine Lift Brackets - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi All,
    Looking for reference pictures of original engine lift brackets for a 1970 LT1. It is also my understanding that the front bracket should be painted silver while the rear bracket that mounts to the bell housing is orange. Is that correct?
    I didn't see anything in the archives specifically for LT1 reference. Was the LT1 brackets LT1 specific or interchangeable with other years/ small blocks?
    Dave
    • 43247
    Re: 1970 LT1 Corvette Engine Lift Brackets
    Originally posted by David Schutzbank (50698)
    Hi All,
    Dave
    Dave------
    The brackets for LT-1 were painted as you described.
    The same lift brackets were used for 1968-70 small blocks, LT-1 or otherwise.
    • Paul O.
      • August 31, 1990
      • 1716
      David
      Do you have the latest 70-72 Judging Guide if not you should. It has the photos and information you need plus so much more.
      • Kenneth B.
        • August 31, 1984
        • 2091
        The were the same but the front ones mounted on al. intakes were silver & the ones on CI. were painted Orange.
        • David S.
          • August 9, 2009
          • 595
          Thanks All.
          Yes Paul, I do have the manual. Unfortunately I left it at the shop and was hoping to go shopping for a rear bracket before I have a chance to get back to the shop.
          Dave
            • 15616
            Thanks All.
            Dave
            David
            The new 1970-72 TIM&JG will tell you that the configuration of the front lift bracket was different for 1970 than for 1971 and newer. I believe we have photos illustrating the differences in the manual.
