72 OIL gauge - NCRS Discussion Boards
72 OIL gauge
  • Rey S.
    • April 1, 1995
    • 277
    72 OIL gauge
    Does any one out there know where I can purchase an electric oil pressure gauge that will look right in my 72. I trust the mechanical gauge. It's the plumbing I don't trust !
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 72 OIL gauge
    Rey if you decide to replace the plastic oil line going from the rear of the engine to the oil pressure gauge I recommend getting a GM replacement because it has the correct fittings which is needed to attach to oil pressure gauge.
      • 43219
      Re: 72 OIL gauge
      Rey------
      The closest you can come would be to use the 1973 gauge. As I recall, 1973 was the first year to use an electric gauge and, also as I recall, the gauge face was virtually identical, if not absolutely identical, to the 1972 gauge face.
      • Michael W.
        • April 1, 1997
        • 4290
        Re: 72 OIL gauge
        '73 gauge is mechanical. '74 is the first year for electrical but the markings are quite different than '72.
        • Rey S.
          • April 1, 1995
          • 277
          Re: 72 OIL gauge
          Hi Jim:
          First -- Thanks for the reply,
          Second where on the back of the engine does it attach ? remembering my engine is a early 502 crate motor so occasionally there can be differences.
          • Mark E.
            • April 1, 1993
            • 4536
            Re: 72 OIL gauge
            Hi Jim:
            I don't know about the crate engine, but the location on the original is on the side of the block, above the oil filter.
            If you decide to keep the original gauge, one tip I was taught is to keep air in the line. In other words, don't bleed the air out of the line. This will prevent hot oil from being in the plastic line and keep the components cooler. Which in turn reduces the chance of failure.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Michael W.
              • April 1, 1997
              • 4290
              Re: 72 OIL gauge
              As the line is deadheaded at the gauge, there's no flow of oil or air.
              • Jim T.
                • March 1, 1993
                • 5351
                Re: 72 OIL gauge
                Hi Jim:
                Rey I did not read all of your first post to see you have a 502. My reference is for the 68 and 70 small blocks that I have.
                • Mark E.
                  • April 1, 1993
                  • 4536
                  Re: 72 OIL gauge
                  To clarify, the suggestion is to install the line so it's filled with air. This means installing it with no special steps like bleeding the air out of the line. I've seen some lines filled with oil, which means either the line was bled or has a leak.
                  Once installed properly there's no flow of oil or air, but the air will compress a bit when oil pressure is applied.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Re: 72 OIL gauge
                    To clarify, the suggestion is to install the line so it's filled with air. .
                    Agreed but the story about 'hot oil' if the line is bled is not correct.
                    • Ken A.
                      • July 31, 1986
                      • 929
                      Re: 72 OIL gauge
                      Use part 6464081 74 electric gauge & associated sender. Colors will match but the '74 reads from 0-80#.
                      The 72-73 gauges reads from 0-70#. You'll also have to get a gauge mounting panel from a 74 & up donor.
                      Gauges are available from any parts vendor.
                      • Mark E.
                        • April 1, 1993
                        • 4536
                        Re: 72 OIL gauge
                        Why?..........
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Ken A.
                          • July 31, 1986
                          • 929
                          Re: 72 OIL gauge
                          If you decide to keep the original gauge, one tip I was taught is to keep air in the line. In other words, don't bleed the air out of the line. This will prevent hot oil from being in the plastic line and keep the components cooler. Which in turn reduces the chance of failure.[/QUOTE]
                          You were taught wrong, it makes no difference-but there is no need to "bleed" the line.
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            Re: 72 OIL gauge
                            Why?..........
                            There's no flow of oil into the line. No flow, no heat.
                            • Mark E.
                              • April 1, 1993
                              • 4536
                              Re: 72 OIL gauge
                              Fluid thermal conduction occurs with no flow. Gases are less conductive than liquids, that's why it's better to leave air in the line.
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
