Paragon service replacement gas tank - NCRS Discussion Boards
  • Justin S.
    • July 3, 2013
    • 305
    Looking for a gas tank for my '70. Paragon sells a 24 gallon. Has anyone used these? If so, are there any fitment issues with the larger tank?
    • 11692
    Re: Paragon service replacement gas tank
    The larger tanks are meant for the 78-and-later cars with the sloped rear deck due to the fastback rear window.
    I would not guarantee that it would fit in your 70.
      • 43273
      Patrick and Justin------
      If Justin is talking about the 78-82 tank, it cannot be used on a pre-78 for several reasons.
      If there is some other retrofit 24 gallon tank available for earlier Corvettes, I am not aware of it.
      Fuel tanks are a major safety item. While the 78-82 tank is safer due to its formed-in-place bladder, the engineering for it is based upon other elements of the 78-82 configuration. Trying to "re-engineer" the fuel system of an earlier car is problematic. 1963-82 Corvettes are dangerous enough as far as the fuel system goes without "re-engineering" compromising it further.
      • Justin S.
        • July 3, 2013
        • 305
        Thanks gents. I'm going to have to call a rep. It says that service replacement tanks for late'69-74 are 24 gallons. I will report back
        • Justin S.
          • July 3, 2013
          • 305
          Rep said that the tank in question was discontinued
