65 vs 64 Front Clip - NCRS Discussion Boards
65 vs 64 Front Clip
  • James C.
    • July 4, 2012
    • 81
    65 vs 64 Front Clip
    Trying to discern if there was a difference on the rails of the fender inside under the hood(fender) that the inner fender comes up to and meets on a 65 vs 64. Did they make any minor changes at the factory? I attached a pic of my 64. The first few inches from the front of the car running towards the cowel is flat then a slight lip starts that runs the rest of the way up across the cowel down the other side.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 65 vs 64 Front Clip
    I think you are just looking at differences in the clean up of the panel after it was removed from the tool and "clean up" as installed. I've seen some cars that have a substantial lip while other none or razor edge.
    • Russ S.
      • April 30, 1982
      • 2163
      James, What you have pictured is the way it is suppose to look.
