Opinion on Engine stamp - NCRS Discussion Boards
  • Raymond H.
    • September 18, 2015
    • 12
    I would like your opinion on this pad.....The Cummings part of the stamp is interesting anyone know what that is. Thanks in advance for your help.
    • 43273
    Re: Opinion on Engine stamp
    Raymond-------
    From what I can see of it, I think the engine stampings are OK. The stamping above them is almost certainly the stamping of a shop that rebuilt the engine at some point in the car's history.
    • Michael J.
      • January 27, 2009
      • 7166
      I usually don't comment on these, but I'm going to go out on a limb here and say it appears NTFP.
      • Raymond H.
        • 12
        Thanks Joe
        Raymond-------
        • Raymond H.
          • 12
          Hey Michael thanks for the response but I don't know what that means NTFP
          • Michael J.
            • January 27, 2009
            • 7166
            Standard NCRS acronym for "Not Typical Factory Production". Which in judging would garner a deduction of points.
            • Raymond H.
              • 12
              Thanks I learn something everyday....appreciate the help
              • Michael J.
                • January 27, 2009
                • 7166
                You're welcome. Not being a mechanical judge (the ones who judge stamp pads, among other things) I don't know how much deduction it would be. As Joe says, most of the pad appears fine, but it is surprising a rebuilder would do such a thing to a valuable area like the stamp pad of a Corvette. Must have been done long ago when these were just another used car.
                • Patrick B.
                  • August 31, 1985
                  • 2011
                  Raymond ---- I agree with Joe. The VIN and Flint stamps look completely original, and the grain is also good. The Cummings part is certainly a shop that rebuilt the engine before anyone cared about stamping pads. At least they left the GM stamping alone which is better than most rebuilders who would have decked it even if it wasn't necessary.
                  • Raymond H.
                    • 12
                    Thanks Patrick
                    • David H.
                      • June 30, 2001
                      • 1558
                      Raymond,
                      Welcome to the Forum.
                      The engine casting number, casting date, plant assembly stamping/partial VIN, and engine pad factory machining marks are all judged by Standard Deduction Guideline #1 found on page 29 of the current Judging Reference Manual. I don't see where any points would be deducted using SDG presuming the casting number/date/assembly date/VIN are also appropriate for your car.
                      The JRM is available (inexpensive) from the NCRS bookstore.
                      Dave
                      • Raymond H.
                        • 12
                        Thanks David
                        • Michael W.
                          • April 1, 1997
                          • 4290
                          I agree with David H in that NO points should be deducted. The rules for the pad surface do not require that the entire surface be 'original' just that some traces remain.
                          • Philip A.
                            • February 26, 2008
                            • 329
                            I would tend to disagree. I do not believe any of the judging rules specify "entire"; it would be naturally presumed anything additional is NTFP. Applying a standard of the word "entire" being absent from the judging standard would allow all kinds of addition modifications, such as pin striping, racing stripes, etc
                            • David H.
                              • June 30, 2001
                              • 1558
                              Philip,
                              There is no NTFP provision for judging engine cases, only the Standard Deduction Guideline #1. Matrix judging (CDCIF) only comes into play when there is no Standard Deduction Guideline for an area.
                              Dave
