What does "PB" mean on AM/FM C2 radios ? - NCRS Discussion Boards
  • Wayne M.
    • February 29, 1980
    • 6414
    You see this "PB" description on window stickers and build sheets.
  • Dave H.
    • August 17, 2010
    • 47
    Re: What does "PB" mean on AM/FM C2 radios ?
    Pushbutton?
    • Wayne M.
      • February 29, 1980
      • 6414
      Originally posted by Dave Hart (52080)
      ... Pushbutton?
      I think you've nailed it, Dave. I need more coffee
      • Dave H.
        • August 17, 2010
        • 47
        Lucky guess. You guys still have reams of knowledge more than I have. That's why I lurk.
        Waitress, more coffee all around.
        • Stuart F.
          • August 31, 1996
          • 4676
          My first thought was "Public Broadcasting"! Shows you how times have changed.
          Stu Fox
          • Loren L.
            • April 30, 1976
            • 4104
            In Canada during certain times of year, it means "Please Boil" before using...........
            • Donald O.
              • May 31, 1990
              • 1575
              PB is the scientific notation for lead.
              You should be using leaded electrons for the power and if need be you should have the radio heads machined to hardened for the frammic valves.
              Now, some will say that using the leaded electrons for the radio power is no longer needed, but me, I use it. I also use 13.5 leaded volts and not the easily available 12.5 unleaded volts. That higher volts and the leaded electrons rally make the radio come to life, especially in the higher frequency bands.
              Just saying.....
              The light at the end of the tunnel has been turned off.
              • Ed S.
                • August 6, 2014
                • 1377
                Probably broke.
                Ed
