67 AC compressor date question - NCRS Discussion Boards
  • Gary N.
    • October 1, 2013
    • 2
    67 coupe Powergluide, February 67 Car,
    this is what is on the back of the compressor, is is correct for my car? Starting from the top:
    A-1
    6555302
    L 10
    thanks!
  • Al R.
    • June 30, 1988
    • 687
    Re: 67 AC compressor date question
    Gary, I'll check mine this morning and get back with you. I, too have a Feb 67 AC w PG (make that my wife does).
    • Peter L.
      • May 31, 1983
      • 1930
      Gary - The compressor back plate on our Sept 66, S/N 1476, build 67 reads
      C220
      6555302
      R 15
      I checked some other Chevrolet/Chevelle AC compressors that I have & there are other formats but the # 6555302 appears on the rear flange of the compressors I checked & the '67 NCRS TIM&JG does indicate part # 6555302 is cast into it below the casting date & there is a photo of the rear flange. Unfortunately, I have not checked other '67 Corvette AC compressor rear flanges so I don't know if other configurations exist.
      FYI, the label on the compressor of our car reads
      5910645
      3.00 lb
      072762
      Pete
      • Domenic T.
        • January 29, 2010
        • 2452
        Peter,
        C 22 0 cast under the manifold would be: C=March, 22 = day, O = 1970. The 6555302 was on all that did not have the thermal switch. (I) is also used on the casting date.
        Dom
        • Al R.
          • June 30, 1988
          • 687
          Hi Gary, sorry didn't get back top you yesterday. I worked on my truck till around 8:30 last night and got to go finish it up hopefully in a little while. Anyway, I think you are OK with the L10 date on your compressor but I think there should be a 6 after the 10 for 1966. Domenic might can chime in on that and let us know for sure. Our compressor has a date of L156 which is Dec 15 1966 for my wife's Feb. 67 vette. The sticker on top of the compressor also has a date of 122262 which is Dec 22 1966 2nd shift I believe.
          • Domenic T.
            • January 29, 2010
            • 2452
            Hi AL,
            Hope all is blowing cold, The clincher here is that the casting dates are raised letters and my guess is that the only one that is raised is the A-1. The long casting number is recessed and L10 would also be recessed if I am correct. No one has figured out the letters and numbers under the long casting numbers yet. I think those may be a batch number or shift.
            Dom
            • Gary N.
              • October 1, 2013
              • 2
              Thanks for all the responses, the A-1 is raised and the others are stamped, do you think this will score ok by a judge?
              • Wayne M.
                • March 1, 1980
                • 6414
                Originally posted by Domenic Tallarita (51287)
                Peter,
                Dom
                Here's an example of the cast letter "I" (September), and the number "1" in the 15 (day of month) 4 = 1964.. I believe the I or 1 used the same character.
                PS: the original picture was shot in portrait format, but it seems that DB software rotates to panorama, and I don't know how to override.
