Detailing exterior of fuel tank - NCRS Discussion Boards
  • Anthony P.
    • October 26, 2011
    • 199
    what product works best to clean the outside of the fuel tank? Normal 50 years of crud! Has anyone had good results?
    • 43222
    Re: Detailing exterior of fuel tank
    Tony------
    Original fuel tanks were terne coated steel. I don't know of any way to restore this finish to its original appearance. If its just dirt and debris, I'd use a good detergent solution and a soft brush. However, that's not going to do anything about oxidation that makes the tank seem dull compared to its original luster.
    • Daniel S.
      • January 14, 2011
      • 307
      I assume the tank is out of the car? I suggest Blue Magic metal polish. I polished a set of big block side pipes that had been on an early Duntov winner for about 20 years and they came out beautifully. Try aggitating the dirt/grime with wax and grease remover first. Then as a second attempt, used very fine steel wool and Blue Magic.
      https://www.amazon.com/BLUE-MAGIC-40...rds=blue+magic
      • Anthony P.
        • October 26, 2011
        • 199
        thanks for the tips, I will start on this today!
