Brake Fluid Cocktail - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    Noticed DOT 3 brake fluid with a small (silicone label) Can that be mixed with regular DOT 3 fluid when topping off? Does the silicone fluid attack the old GM Caliper seals?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Brake Fluid Cocktail
    You sure? Never heard of DOT 3 silicone brake fluid and cannot find any reference to it.
    • Frank K.
      • January 1, 2000
      • 319
      Here is the mfg Wearever, premium synthetic, for abs disc,and drum brake systems. Dot 3 Brake fluid
      • Michael W.
        • April 1, 1997
        • 4290
        synthetic,
        Ah- 'synthetic'. All brake fluid is synthetic, irrespective of DOT standard or whether it's silicone.
        • Edward B.
          • March 29, 2013
          • 691
          Frank, synthetic is not silicone. As a matter of fact, ALL brake fluid is synthetic, so any dot 3 can be mixed with any other dot 3. Adding the word "Synthetic" to the packaging is just a marketing ploy.
          However, you CAN'T mix dot 3 with silicone.
          Edit: Mike beat me to it!!
          Ed
          • Frank K.
            • January 1, 2000
            • 319
            The reason I was concern was the napa brand mentions nothing about synthetic on any the containers I have which are not that old! (three years) Thanks for all the info you are never to old to learn!
            • Edward B.
              • January 1, 1988
              • 537
              Does the small label state "silicone" or "synthetic?"
              • Frank K.
                • January 1, 2000
                • 319
                It is a large label and it does say synthetic but do they make silicone in dot 3?
                • Edward B.
                  • March 29, 2013
                  • 691
                  No, silicone is Dot 5.
                  Ed
                  • John L.
                    • February 20, 2009
                    • 186
                    And to make it more confusing there is a DOT 5.1 non silicone ...
                    • John D.
                      • June 30, 1991
                      • 875
                      SAE paper 810804 says DOT 3 and DOT 5 can be mixed with no adverse affect on brake performance or elastomers. I wouldn't rush out and do it though..
                      • Bill S.
                        • April 30, 2002
                        • 154
                        Bill Strobel
                        Owner Independent Towing
                        Fayetteville, NC
                        1979 Corvette White/Red L-82 4 spd
                        Only 4,200 miles
                        Do It Right or Don't Do It At All
