Where can I find an installation diagram for a 1970 350/350 with air conditioning? I did not see it in the AIM. Thanks.
1970 350/350 Radiator Installation Diagram Help
Bill Hyndman
The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
1962 Big Brake Fuelie
1965 Fuelie Convertible
1968 L89 Convertible
Tags: None- Top
Re: 1970 350/350 Radiator Installation Diagram Help
The radiator installation is the same as the LT1. Copper radiator and core support is the same. Auto trans uses a little different radiator, but basically the same. The A/C components bolts in front of the radiator. That will be in the C60 section. Just follow the LT1 radiator info in AIM, you should be ok.
Gary- Top
