PCV Valve Question - Big Cam - NCRS Discussion Boards
  • Al P.
    • February 15, 2011
    • 87
    My 1967 427 BB engine has a big overlap cam that has 8-9 inches of vacuum at idle. What PCV# valve should I be running? I have read that the stock one called for a 435 HP is not the correct one for this cam as its not the 435 HP Cam. Mine is more close to a L88 cam but a bit bigger - What is the PCV part Number for a 1968-69 L88 Corvette? I think its 736 but not sure. Thank You
    • 43290
    Re: PCV Valve Question - Big Cam
    Al-------
    L-88 used an AC CV-746C and that's exactly the one you should use.
    • Al P.
      • February 15, 2011
      • 87
      Thanks Joe - Are they still available to buy anywhere?
        • 43290
        Al-------
        Yes, still available from GM or Delco dealers. GM part number is 6484525.
        • Al P.
          • February 15, 2011
          • 87
          Thanks Joe!
