LOWER BALL JOINT RIVETING tool from Long Island Corvette - NCRS Discussion Boards
  • Irby G.
    • November 1, 2001
    • 267
    LOWER BALL JOINT RIVETING FIXTURE * 55-42B
    $40.00
    $40.00
    AIR HAMMER RIVETING BIT * (FOR STEEL RIVETS) 55-42C
    $20.00
    $20.00
    Has anyone used these before?
    Not completely sure that this is the same tool, but I believe this is it and the procedure that they used.
    In this post, we will show and demenstrate the process taken to install our 1963 Corvette Control Arm.
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: LOWER BALL JOINT RIVETING tool from Long Island Corvette
    I always thought the rivets were put in from the other side and peened on the outside.
      • 43219
      Timothy-------
      They are. The lower ball joints have the rivet head on the inside and the peened end on the outside. The upper ball joints have the rivet head on the outside and the peened end on the inside.
      • Steven B.
        • April 11, 2012
        • 233
        So in essence, the rivets go in from the top of the upper and lower control arms?
          • 43219
          Steven------
          The lower ball joints are not riveted from what I would describe as either the top or the bottom. The rivets install from what I would describe as the side (i.e. parallel to the ground as installed on the car). The rivet head is located on what I would describe as the inside of the control arm (i.e. the rivet head contacts the ball joint) and the peened end is on the outside of the control arm.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            Irby, I have that lower fixture tool if you want to borrow. USPS Priority mail small flat rate both ways would be about $13 to the island. I have the upper tool if needed too but bigger box for both. I won't be needing them for a long time. Drop me a PM if so. You can make your own air hammer peening tool from a old air chisel or a cheapie from your local stores if available there. Cut the end off and use a dremel with small rounded grinder bit to shape the end depression.
            lower - that screw is made to hold it in place using the rubber bumper hole in the ctl arm
            upper
