the heat and air is only coming out from the floor ducts. no air is coming out of the other vents or the defrost.
1977 hvac issue
Re: 1977 hvac issue
David sounds like a vacuum hose under the hood may have been disconnected or feel off. this system operates on vacuum.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 1977 hvac issue
David------
In addition, it could also be caused by failure of one of the system's vacuum actuators or the rotary switches in the system controller in the forward console.In Appreciation of John Hinckley- Top
- Top
