C4 ecm - NCRS Discussion Boards
C4 ecm
  • Frank K.
    • January 1, 2000
    • 319
    C4 ecm
    How do you reference the numeric and alphabetic white sticker on the ECM? Is the SERV NO the part number? Are all GM compatible using the same engine? Example 1993 SERV.NO-16159278 with three additional group of letters and numbers
  • Kenneth P.
    • November 17, 2015
    • 151
    Re: C4 ecm
    The service number (left top of label) is the part number for the ECM for that year. The 4 letters on the top right is the BCC (Broadcast code) which is the chip (eprom) inside which holds the program setting for your car. From the BCC you can tell the engine, transmission and rear gear ratio that it is programmed for.
    • Frank K.
      • January 1, 2000
      • 319
      Re: C4 ecm
      So a replacement would have to match
      The serv number is on the top line. the line under neath that is the broadcast code and the third line . I have three lines
      • Kenneth P.
        • November 17, 2015
        • 151
        Re: C4 ecm
        For the most part yes although the ECM itself is used in other GM cars under a different service number. The chip (eprom) is specific to the car and should match. Now the chip is removable and can be placed into another ECM. Most problems are with the circuit board in the ECM and not the chip itself.
        • Frank K.
          • January 1, 2000
          • 319
          Re: C4 ecm
          Does heat and vibration affect the board? Can the chips be duplicated?
          • Kenneth P.
            • November 17, 2015
            • 151
            Re: C4 ecm
            Heat and vibration can be factor in circuit board issues.
            The 93 was the last year for the black box style ECM with a prom chip. The same ECM was used in 93 camaro z28.
            • David K.
              • September 30, 1979
              • 241
              Re: C4 ecm
              They can be rebuilt, check out SIA ELECTRONICS. I have not had any work done here, so check it out for yourself.
              Dave
              • Frank K.
                • January 1, 2000
                • 319
                Re: C4 ecm
                Can the boards be sprayed with an electronic spray cleaner as a measure for longevity. so the prom is removable and who might be abel to duplicate?
                • Kenneth P.
                  • November 17, 2015
                  • 151
                  Re: C4 ecm
                  The prom is factory but there are businesses that will burn a new prom for your car. You can usually find them on sites like eBay or any number of corvette part sites. What is the 4 letter BCC on your ECM?
                    • 6948
                    Re: C4 ecm
                    Frank, why do you think you need a ECM??
                    • Frank K.
                      • January 1, 2000
                      • 319
                      Re: C4 ecm
                      First of all i am troublshooting a closed loop prblem that comes and goes. Second i am buying spare parts because of the shortage of NOS. Third i bought this car new and want all the education on these C4 i can gather! This car is a keeper!
                      • Kenneth P.
                        • November 17, 2015
                        • 151
                        Re: C4 ecm
                        The 92 and 93 C4 used the same ECM (16159278) and proms. The is basically 4 proms for the LT1 one for the 6 speed and 3 for automatics with different rear gear ratios. Most sellers on eBay ask way to much for used ECM but every so often there are good deals. I picked up one this past summer on eBay for my 90 for less than $60.
                        I've attached an article I found on the internet on proms that you may find interesting.
                        • Frank K.
                          • January 1, 2000
                          • 319
                          Re: C4 ecm
                          The number I have on the second line 86bafl m131590539
                          • Kenneth P.
                            • November 17, 2015
                            • 151
                            Re: C4 ecm
                            The second line is the bar code. The BAFL in the bar code will be to the top right of the label. The BAFL is the BCC of the prom that is for a LT1 with 6 speed manual transmission and a rear gear ratio of 3.45. If you were to look at the prom it should have part #16173866.
                            I spent some time researching the ECM for my 90 when I was getting it ready for flight judging. My car had a re-manufacturer ECM when i got it and I wanted to find the correct ECM label since it was listed in the JM. Over time it kind of became an obsession of mine LOL.
                            • Frank K.
                              • January 1, 2000
                              • 319
                              Re: C4 ecm
                              that is correct! Now I would like to find a scan tool for this OB1 set up. I can pull codes with a paper clip by jumping out two pins or just by using my old code scanner but with this type of distributor and computer I need all the help I can get.
