54 Generator Mounting Bolt - NCRS Discussion Boards
  • Eric F.
    • June 30, 2003
    • 319
    The early 54 I'm working on uses two 5/16 x 1 1/2" bolts to attach the generator to the bracket which is attached to the engine block. However, the Corvette Parts Catalog dated June 1954 lists the attachment bolt as part number 809763 ( a "through" bolt sized at 5/16-18 x 7 7/78". I have photos from 1954 Vin's 1147 & 4273; both are survivors but I the extensive list of photos doesn't show the bottom generator bolt(s). I've attached a photo of my setup.
    Does anyone know which is the correct mounting bolt(s)?
    Thanks in advance for your assistance,
    Eric
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 54 Generator Mounting Bolt
    Typically they are TR or WB and they mount from the inside out
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Eric F.
      • June 30, 2003
      • 319
      Chris,
      There are two WB bolts on this engine and I think you are telling me they need to be turned around so the nuts and washers are on the outsides of the bracket.
      Have you ever seen the generator installed using one long bolt as the 1954 Corvette Parts catalog indicates?
      Eric
