59 Block # - NCRS Discussion Boards
59 Block #
  • Dr F.
    • October 2, 2016
    • 16
    59 Block #
    Hello, Any thoughts on the correct block casting number for a 1959, #3376 would be greatly appreciated. Regards, Chuck
  • Joe M.
    • April 30, 1990
    • 1343
    Re: 59 Block #
    The block casting number for all 1959 Corvettes is 3756519. Did you mean acceptable block casting date for VIN 3376?
    • Dr F.
      • October 2, 2016
      • 16
      Re: 59 Block #
      Hello Joe. Thanks for your note. Two websites state that two blocks were used in the 1959: 3737739 in 1958s and "early" 1959s, and 3756519 in late 1958s through 1961s. What do you think? Chuck
        • 43295
        Re: 59 Block #
        Chuck-------
        The 3737739 block may have been used for very early 1959 Corvettes. However, I would say that your car is quite a ways from being a very early car as it was built about 4 months into 1959 production. It's like this, though: if you could find a block that was cast about 1 month prior to your car's build date, then that block, whether it's a 3737739 or a 3756519, could have been installed in your car. My guess is that you won't find a 3737739 that "fits the bill".
        • Dr F.
          • October 2, 2016
          • 16
          Re: 59 Block #
          Thanks very much, Joe. What you say makes sense. Have a good night....Chuck
          • Joe M.
            • April 30, 1990
            • 1343
            Re: 59 Block #
            I misspoke about "all" 1959s having the 519 block, but I agree with the other Joe, it is unlikely that the 739 blocks would have still be available when your car was built. We don't have a definitive VIN date definition for what is early, middle, or late build, but I would not consider VIN 3376 early build. I would be looking for a 519 block with an early Jan. 1959 casting date.
            • Dr F.
              • October 2, 2016
              • 16
              Re: 59 Block #
              Thanks, Joe M. Let me know if you ever see either block with a November, December or early January casting date! Regards, Chuck
              • Bill M.
                • April 1, 1977
                • 1386
                Re: 59 Block #
                I agree.
                I have '59 #2520 and have been watching for spare blocks dated Nov. '58 for decades. I have bought 2, both Flint 519s.
                I've never seen a 739 dated Nov. '58.
                If you find a 739 dated correctly make sure it is a Flint block. Maybe Tonawanda switched from 739 to 519 at a different time?
                • Dr F.
                  • October 2, 2016
                  • 16
                  Re: 59 Block #
                  Hello Joe, Still searching for a 3756519 block. May I ask you about cylinder heads? Is 3755550 correct for a 1959 fuel injected model? Thanks very much. Chuck
                    • 43295
                    Re: 59 Block #
                    Chuck-------
                    Yes, the 3755550 is the correct head casting for most 1959 Corvettes of all engine options. Very late-build cars, after about May, 1959, probably received the GM #3767465 casting.
                    You need to be careful, though, that you're looking for a Saginaw-cast head and not a Tonawanda-cast head. Among other differences, the Tonawanda-cast heads usually have a "T" casting symbol visible in the under rocker cover area.
                    • Dr F.
                      • October 2, 2016
                      • 16
                      Re: 59 Block #
                      Thank you Joe. I'll check them out. Chuck (62859)
