need help with gm part # - NCRS Discussion Boards
+ More Options
Posts
  • Mike M.
    • May 31, 1974
    • 8397
    part # 450897 was it a pan head phillips or a clutch head fastener? in advance, thanks joe. mike
    • 43242
    Re: need help with gm part #
    Mike-----
    Well, that is an ANCIENT part number. If it was ever available in SERVICE (which I doubt), it was discontinued prior to about 1956.
    I can tell you this, though: other screws of this part number series which I can find were pan head, cross recess (phillips). I can't guarantee that the GM #450897 was, though.
    • Mike M.
      • May 31, 1974
      • 8397
      thanks joe. mike
      • Tom B.
        • March 1, 1978
        • 720
        Mike,
        I find some pn 450xxx bolts that were removed from service in the 1966 to 1971 period but not yours. Some were replaced and others just were removed. The only 450xx number left in the GM Standard Parts Catalog in 1982 was 450405. It is a 6-32 1/2" Fillister head cross recess screw, cad or zinc. I would suspect that all 450xxx screws were Fillister head.
        Tom
        • Mike M.
          • May 31, 1974
          • 8397
          thanks tom. i'm pretty sure the 450879 was a 1/4" coarse screw. like to know if clutch or phillips. thanks again, mike
          • David B.
            • March 1, 1980
            • 689
            450897 is a7/8 oval head cross recess taping screw type G nominal size 12, 24 threads per inch
            • Mike M.
              • May 31, 1974
              • 8397
              thanks much dave; regards, mike
