C2 tach cable - NCRS Discussion Boards
C2 tach cable
  • Noel B.
    • April 18, 2016
    • 81
    C2 tach cable
    What is the best way to lubricate a noisy tach cable? I purchased some Cable Ease but am not sure how to proceed. Can I remove the inner cable from the sheath from above to lubricate it and then reinsert it? It's tough to get at the cable connection to the tach under the dash. Thanks.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 tach cable
    Remove the inner cable and apply a little of the lube. If you use too must lube it will work its way into your tach and could do some damage.
    • Russ S.
      • April 30, 1982
      • 2162
      Re: C2 tach cable
      Yes, You can pull the cable out from one end only.
      • Timothy B.
        • April 30, 1983
        • 5193
        Re: C2 tach cable
        Noel,
        I just cleaned and lubricated the speedometer and tach cables on my 63 car. After cleaning all the grease on the cable and housing I bought some speedometer cable lube, this looked like powdered graphite and mineral spirits with the consistancy of water. When finished I could hear the cable when spinning with my hand so I again removed the inner cable and used a very small amount of moly grease and lubed the inner cable working it in and out from the bottom. After I worked it around good I removed the inner cable and installed it back from the top, I had these cables removed from the car so it was easy. The moly grease has graphite and I believe it will work fine just don't use to much.
