Which speedo drive gear do I need 59 P/G - NCRS Discussion Boards
    • 6956
    I have a 59 283/230 power glide from what I see the rear gear is suppose to be a 355 Ratio ? what the color/ number of teeth
    for this trans.
    • 43277
    Re: Which speedo drive gear do I need 59 P/G
    for this trans.
    Edward------
    Assuming that you do have a 3.55:1 rear gear ratio, you require driven gear GM #3708142. This is a RED nylon gear of 21 tooth count. However, this gear is different from later 21 tooth red gears which are far more common. The 3708142 has a longer drive shank ("stem") than the later gear.
      • 6956
      Thanks Joe, yes the know the gear is a tad longer.some of the Vender's sell the correct length.
      • Bob W.
        • December 1, 1977
        • 803
        Edward So who sells the gear with the correct length? And what is the correct length?
        Thanks Bob
