1964 convertible original paint - NCRS Discussion Boards
  • David R.
    • February 1, 1990
    • 71
    Where would one look for traces of the original paint if the body has been stripped and repainted a different color?
    There must be somewhere on the car where the original paint would be left untouched.
    Any ideas?
  • Jim D.
    • 2885
    Re: 1964 convertible original paint
    Look deep inside the door hinge pockets, behind kick panels & door panels, in fenderwells and all the other hidden areas. To do an "undetectable" color change requires a lot more labor than most are willing to expend.
    • Russ S.
      • April 30, 1982
      • 2163
      Are you saying the trim tag is gone or replaced?
        • 6956
        David to add the mix, the piller posts are a area that sometimes un-touched , but requires the exterior trim on windshield be removed.
        • Ken R.
          • August 31, 1980
          • 309
          Look in the storage area behind the seats. And also under the rear carpet. Usually there is over spray in there as to the body color.
