1963 clutch rod question - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    This clutch rod nut is adjusted all the way at the end of this rod and the clutch pedal is still just about off the floor. It is the correct length (18") and the clutch fork rod is also the correct length (11 1/2").
    Other than extending the clutch rod by about an inch, does anyone have any other thoughts on how to remedy this issue? does anyone have any thoughts as to why this is happening?
    Jerry
    • 43287
    Re: 1963 clutch rod question
    Jerry
    Jerry------
    I suspect the problem originates with the clutch. Corvettes are VERY sensitive to correct dimensional configuration of the clutch assembly, flywheel, and release bearing. It may be that the currently installed clutch was OK for awhile but as it became worn, you ran out of adjustment.
    • Gerald C.
      • June 30, 1987
      • 1314
      Thanks Joe. I guess my immediate remedy is to extend the clutch rod about an inch so that I can pick up the adjustment. I can replace the clutch, etc. over the winter.
        • 43287
        Jerry------
        The 1966-67 pedal rod, GM #3888213, which is also SERVICE for 1963-65, is 19-3/8" overall length. It's GM-discontinued but I expect it's available in reproduction.
        • Loren L.
          • April 30, 1976
          • 4104
          Have you changed the throw-out bearing?
          • Gerald C.
            • June 30, 1987
            • 1314
            Thanks Joe. I'll reach out to LICC or paragon in the morning.
            • Gerald C.
              • June 30, 1987
              • 1314
              Loren,
              No I haven't as I just got the car back today from the restorer. Just trying to piecemeal the car for a couple of shows before the winter.
              • Rich G.
                • August 31, 2002
                • 1405
                Could be wrong TO bearing. When I bought my 66 14 years ago it had a home made clutch rod so I figured I be a good NCRS boy and get the correct one. Then the clutch wouldn't work anymore. The tranny came down for other reasons and putting the correct T.O. Bearing in made everything work together.
                I'm not sure, but at the time I think I was told that the passenger car and corvette bearings were different. Others here I'm sure will know better than I.
                Rich
                  • 43287
                  Rich
                  Rich------
                  Yes, the bearings were different. The bearing generally used for passenger cars was 1-7/8" overall length; the Corvette bearing was 1-1/4" or 1-7/32" overall length. Sometimes, parts counter guys just assume that the 1-7/8" bearing "works for all Chevys". That can begin a chain of events that ends up with a huge headache for the installer if he doesn't detect the problem before installation. However, usually if the 1-7/8" bearing is installed in a Corvette one cannot achieve any adjustment from the get-go. That's probably why someone added some length to the clutch rod; it was easier than "going back in".
                  By the way, the 1-7/32" bearing was discontinued years ago and replaced by the 1-1/4" so, as of that time, all 1956-81 Corvettes use the 1-1/4" bearing. I think the 1-7/32" bearing was an attempt by GM engineers to "fine tune" the finicky 63+ Corvette clutch actuation system as was the the oddball 1-3/8" fork stud. They finally gave up on both as counterproductive or a "failed experiment" and went back to pre-1964 parts before the end of C3 production.
                  • Bob R.
                    • June 30, 2002
                    • 1596
                    You may have had the flywheel machined which would cause the problem you are having. I had to install shims on my flywheel to get the proper adjustment on my car after have the flywheel machined.
                    • Timothy B.
                      • April 30, 1983
                      • 5202
                      Gerald,
                      I would start at the clutch pedal bracket that bolts to the pedal under the dash and check that it's the correct 1963 -65 pin location. You stated the clutch rod is 18" and the clutch fork rod is the correct 1963 part. That leaves the bellcrank to verify as the 63 part and there is information in the archives about that.
                      If you find the linkage is correct the rubber boot can probably be moved to give you a look at the throw out bearing. If that appears to be 1 1/4" then you are going to need to take it apart. I had a problem with my 67 clutch when I bought it where if I adjusted the linkage for some free play the clutch would not disengage fully when pushing the pedal down to the floor. The problem turned out to be the pressure plate, apparently if the surface is turned shims are used to correct overall height. Took it to a rebuilder that did truck clutch and brake work etc. and when I got it back all was fine.
                      • Gerald C.
                        • June 30, 1987
                        • 1314
                        To All,
                        I replaced the clutch rod with the replacement for a 66-67 that Joe Lucia had suggested and it worked great. I'll address everything else in the clutch assembly over the winter. Thanks everyone!
