1972 Power Brake Booster Check Valve - NCRS Discussion Boards
  • Christopher K.
    • September 10, 2007
    • 311
    I know the valve changed sometime after 1970, so I would like to find out which is correct for 1972. I've seen ​both Pic 1 and 2. And if it's Pic 2, what number should be in the square?
    Please excuse me if this is covered in the NEW judging guide, I will get one!
    Thanks for the help,
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
    • 6957
    Re: 1972 Power Brake Booster Check Valve
    Chris, I just looked at my 72 and it appears to have a square with the number 6 in the middle. it is not at all like your first pic. although I have seen them many times before, not sure on the year of your check valve.
    • Larry M.
      • December 1, 1986
      • 541
      Chris,
      The valve on our 1972 matches what you show in your second picture.
      If there is a number in the square on the face of the valve, I'm not able to discern it. The new JG doesn't mention a number, only that the valve is painted gloss black along with the vacuum booster.
      Larry
      • Christopher K.
        • 311
        Ed and Larry, thank you for those replies. I wonder what the significance of the numbers is? I've seen 1, 2, and 4.
        Chris
          • 15633
          Just a guess, but I suspect that number is the mold cavity number so the manufacturer can track any quality issues.
          • Christopher K.
            • 311
            Thanks Terry,
            I really had no idea on that one, appreciate the reply.
            Chris
              • 15633
              Thanks Terry,
              Please understand that is only a guess on my part, and I have nothing to support it other than my gut feeling.
