Captain Lees Spra Strip Discontinued??? - NCRS Discussion Boards
  • Allen N.
    • January 1, 2003
    • 288
    Many threads recommend Captain Lees for paint removal on fiberglass. I have been searching for somewhere to purchase it, and everywhere I look it is shown to be discontinued.
    If it is truly discontinued, what paint stripper do you recommend?
    Allen
  • John D.
    • June 30, 1991
    • 875
    Re: Captain Lees Spra Strip Discontinued???
    Happened to be standing nearby when he won the corvette raffle at Carlisle years ago...wonder what year that was ?
    • Jim D.
      • 2884
      Allen
      I tried Capt. Lees many years ago. This product is all I've used for over 30 years. Far superior - http://www.autobodytoolmart.com/klea...4-p-14857.aspx
      • Donald H.
        • November 2, 2009
        • 2580
        Jim,
        Have you found it to be very safe on the fiberglass?
        Have you used the Klean-Strip product on anything with a hard 2 part primer base? I stripped my hood which had a base coat/clear coat finish and PPG 2 part epoxy primer. Really hard fresh finish. The Capt Lees worked great on the car body, which had about three layers of old finish, but really didn't work at all on the fresh base coat/clear coat and epoxy primer on the hood.
        I then tried a Klean-Strip Aircraft stripper (picture attached). Warning: the product picture below is not the fiberglass version in Jim's post above. You don't want to use what I have picture anywhere on you vette fiberglass. If you leave it on to long it will actually start eating the glass.
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • Jim D.
          • 2884
          Don, I've only used it on lacquer and enamel. I never tried it on BC/CC. When stripping factory lacquer, it pretty much stops at the factory primer. It won't do anything to fiberglass. I've stripped and painted several and never had any issue with it. The first car I used it on was my 1960 back in 1985. No problems have presented themselves 30 years later.
          • Allen N.
            • January 1, 2003
            • 288
            Jim and Don,
            Thanks for your responses. I will be trying the Klean Strip.
            Allen
            • Gary C.
              Administrator
              • October 1, 1982
              • 17659
              Allen,
              Used both many moons ago. The aircraft strip works as good if not better than Captain's Lee's. Be cautious and only do a small area at a time such as 1x1 ft or 2x2 ft, but no more. We used it on 1956-7. If left on too long it will soften the the fiberglass.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Jim D.
                • 2884
                Gary
                I've never had that experience even applied to bare fiberglass but maybe the earlier glass was more fragile.
