Does anyone know were the main dash ground wire goes... I was pretty sure it went on the speedometer housing above the temp gauge area... I had to fix the speedometer so out came the dash. I have a wiring diagram but grounds are not that clear on it...
I checked the dimmer its ok... and the fuse... no dash lights... I will try and run a jumper ground wire tomorrow to make sure they are working.
Does someone know all the ground spots, I would really like to check and clean them all, found the obvious ones.
thank you.
thank you.
