SB vs BB differential - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    Are there any differences between the SB and BB differential, other than the stub axle caps? Were the stub axles beefier, more robust internals, etc?
    • 43247
    Re: SB vs BB differential
    Roger------
    No difference other than the stub axles. The stub axles are not really beefier although, obviously, the cap for u-joint attachment makes them somewhat stronger.
    • Roger G.
      • October 11, 2012
      • 268
      Thank you, Joe
      • Gary R.
        • April 1, 1989
        • 1799
        Roger
        Joe is correct, other then stampings there was no difference. However there is a difference during the run of the 63-79 iron diff's some are much stronger/weaker then others. For example 68's are weaker then 69's because there was a posi casting change in '69. Then in 71 the spiders became stronger but the clutches weaker.
