1963 Coupe Frames - NCRS Discussion Boards
1963 Coupe Frames
  • Sven C.
    • July 18, 2015
    • 187
    1963 Coupe Frames
    I have looked at a bunch of 1963 Coupes and noticed that a very small minority have braces on the frame inboard of the kickups. I have been told that no 1963 frames had braces in those locations and it is more than likely a 1964 or 1965 frame. The first picture shows the brace from one car and the link shows the brace to another car. Confused and wondering if someone could clear this up for me please. Thanks.
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 Ontario NCRS Regional Meet (Regional) at 09-14-2023
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 National Convention-French Lick (National) at 07-27-2023
    1963 Corvette: Flight Judging Award (Top Flight) at NCRS Indiana Regional (Regional) at 04-28-2022
    1963 Corvette: Flight Judging Award (Top Flight) at Ontario Chapter judging Meet 2021 (Chapter) at 09-18-2021
    • 6940
    Re: 1963 Coupe Frames
    Sven, I have never seen a 63 with the support plate welded, just 64 is when it started, Are there any sign's of a E/brake bracket welded to transmission cross member, as 64 was a different set-up, I just noted that in your pic the E/ cable going to the rear brakes left and right are not in the spot I normally see them, They are generally side by side on frame rail.
    • Rick A.
      • July 31, 2002
      • 2147
      Agree with Mr. Johnson
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
        • 43212
        http://nebula.wsimg.com/7a4332819b01...&alloworigin=1
        Sven------
        In this case, there's a more-or-less easy way to determine if the frame is original to the car. Just check out the VIN derivative stamped on the frame. You'll find the location and procedure to observe in many posts in the archives.
        In fact, for other reasons, any Corvette owner that's not the original owner of their car should check to make sure the VIN derivative on the frame matches the VIN plate.
        • Sven C.
          • July 18, 2015
          • 187
          Thanks to everyone for responding.
          Ed. The first pic I have attached here is from the first vehicle and it shows a crappy weld job for the ebrake bracket.... I don't have one showing the transmission cross member. The link is to the second car showing the ebrake bracket and transmission cross. Please let me know what you think. Thanks.
          • Bob W.
            • December 1, 1977
            • 802
            Sven When I clicked the link for the other photo the first thing I noticed was the holes for side pipes. I think that is a 65-67 frame.
            Bob
            • Bob R.
              • June 30, 2002
              • 1595
              That doesn't look like the way my 63 e brake bracket was welded. I don't think that is a real 63 frame.
                • 6940
                Sven, the posts above the guys are correct. its appears to be a replacement frame.
                • Donald L.
                  • November 1, 1981
                  • 140
                  That corner gusset on the frame was not even on the early 64 frames. So there is no way someone could say, well my 63 was very late that is why it has them. It would have to be real late 63 built around Jan 64.
                  • Dan H.
                    • July 31, 1977
                    • 1369
                    My 64, sn 13708, has no gussets.
                    1964 Red FI Coupe, DUNTOV '09
