How many shims should I start with when installing my trailing arms? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1396
    Guys,
    getting ready to install my trailing arms and I don't know how many shims were in it when it came apart. How many should I start off with during initial assembly?
    Mike
  • Jim D.
    • 2885
    Re: How many shims should I start with when installing my trailing arms?
    I put an equal number of shims on each side of the arm until the "pocket" is full. I use that as a starting point when I do an alignment.
    • Russ S.
      • April 30, 1982
      • 2163
      All of them. About 1/2 on each side. Use a couple of thin ones to give the shop a combination to work with.
      • David H.
        • June 30, 2001
        • 1545
        Originally posted by Michael Leonard (46610)
        Guys,
        Mike
        Mike,
        Is the body on the frame? If body off, then Van Steel's suspension video shows a rough alignment procedure. Procedure depicts alignment using the frame rails.
        Dave
